Webcast-Catalyst9k
NAT with simultaneous pool and static with same IP
I've seen a router with the following NAT configuration (this is from "show start"):
ip nat pool SMTP-NAT-pool 63.x.x.34 63.x.x.34 netmask 255.255.255.224
ip nat inside source list SMTP-NAT-out pool SMTP-NAT-pool overload
ip nat inside source list any-NAT-out interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.129.19 25 63.x.x.34 25 extendable
ip nat inside source static tcp 192.168.129.14 80 63.x.x.34 80 extendable
ip nat inside source static tcp 192.168.129.14 443 63.x.x.34 443 extendable
ip access-list extended SMTP-NAT-out
permit ip host 192.168.129.34 any
permit ip host 192.168.129.31 any
permit ip host 192.168.129.19 any
permit ip host 192.168.129.14 any
permit ip host 192.168.129.131 any
permit ip host 192.168.129.149 any
ip access-list extended any-NAT-out
deny ip host 192.168.129.34 any
deny ip host 192.168.129.31 any
deny ip host 192.168.129.19 any
deny ip host 192.168.129.14 any
deny ip host 192.168.129.131 any
deny ip host 192.168.129.149 any
permit ip any any
There are a couple of issues here. First, the "ip nat inside source static tcp 192.168.129.19 25 63.x.x.34 25 extendable" command will simply disappear from the running config anywhere from immediately to a few hours after being entered. Any ideas as to why this would be happening?
Second, I'm seeing some strange entries in the translation table such as:
tcp 63.x.x.40:156 63.x.x.34:26 216.64.173.2:46835 216.64.173.2:46835
tcp 63.x.x.40:95 63.x.x.34:26 216.64.173.2:53577 216.64.173.2:53577
63.x.x.40 is the ip address of the Fa0/0 interface. So, it seems to me that the router is double-translating traffic, i.e. 192.168.129.34 gets translated to 63.x.x.34 which then gets translated to 63.x.x.40. Is this possible? I thought once a packet had been permitted or denied through the NAT process, it was then forwarded out the interface.
The goal here is to send port 80 and 443 to a Web mail server but send port 25 to the SMTP server. Outbound traffic from the hosts in the SMTP-NAT-out ACL needs to show up on the Internet as 63.x.x.34.
I've been looking at NAT features such as extendable, NAT virtual interfaces, and route maps but I have yet to find an article on CCO or NPC that really explains when and why these features would be used and what problems they solve.
If anybody has any ideas as to why we're seeing the disappearing command or any suggestions as to other possible approaches to the goals, they would be much appreciated!
340
