NATing over Site-to-Site
theis is my VPN Site-to-Site:
myServer->myASA5505<----->otherASA<-otherServer
phase 1 work, phase 2 fail because otherASA expect my traffic to use myASA5505's IP and it is using myServer's IP
so here is the question:
How do I NAT myServer to go out myASA5505 using's the ASA outside interface address?
Hall of Fame Super Blue
Re: NATing over Site-to-Site
Ofir
Your crypto mpa access-list needs to use the Natted IP of your server and not the real IP eg.
remote network = 172.16.5.0/24
server real address =- 192.168.5.1
ASA outside interface = 195.177.12.1
access-list vpntraffic permit ip host 195.177.12.1 172.16.5.0 255.255.255.0
the above is what your crypto access-list should look like. At the remote end it should be
access-list vpntraffic permit ip 172.16.5.0 255.255.255.0 host 195.177.12.1
Jon
few corrections:
remote network is /32 - does it change anything (other then the mask)?
when you refer to server real address that is myServer or the other side?
"remote network is /32 - does it change anything (other then the mask)?"
No mine was just an example, change to fit your scenario.
"when you refer to server real address that is myServer or the other side?"
Your server that you are Natting.
Jon
109
