Native Catalyst 6500 with SUP 720.
I'm looking for info about private vlan and vrf on 6500. Can these work together? May I put a private L3 interface into a VRF?
Thanks.
Regards.
Andrea.
VIP Super Bronze
Re: Native Catalyst 6500 with SUP 720.
Hi Andrea,
I don't see why not.  Both VRF and private vlans are supported on Sup-720
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856_ps4835_Products_Data_Sheet.html
Reza
Hello and many thanks for help.
I remembered that not all Catalyst support private VLAN on a VRF-Lite.
Regards.
Andrea
Hall of Fame Super Silver
Hello Andrea,
VRF is an OSI layer 3 concept and private Vlans are an OSI layer2 concept so I don't see why they couldn't be combined if desired.
But of course implementation choices may lead to a different result.
the only requirement is that you cannot configure SVI for secondary vlans
From a practical point of view you should be able to implement multiple VRFs instead of one VRF + private vlans with no problems of scalability.
Also DAI, DHCP snooping may be an alternative to private vlans.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/pvlans.html
Hope to help
Giuseppe
Hello Giuseppe.
I need to combine VRF-Lite, private VLAN and VACL for a backup solution using the Catalyst 6500 at core.
With VRF I can create an intervlan (private primary vlans) routing istance, separed from GRT. With Private VLAN e VACL I can apply security also.
What do you think about?
Regards.
Andrea
533
