native untagged
julxu
hi
I have glable configured "vlan dot1q tag native", I guess that means all native vlan will be tagged.
I need one port (cat6500) with native vlan untagged.
do I have power untag only on the port, not take glable configure out,
Any comments are appreicated
thanks in advance
julxu
5 Replies 5
podhillo
There can only be one native Vlan, that has to be defined globally.If you want it to be tagged it has to be configured globally . You can not change it per interface basis.
podhillo
Podhillo,
I do not entirely agree. On different trunks, you can have different native VLANs. While not a recommended design, it nevertheless is possible.
I believe that the OP wanted to deactivate the tagging of a native VLAN on a selected trunk while having it activated on all other trunk using the global configuration command vlan dot1q tag native. Unfortunately, I don't know whether there is a command for something like that.
What I can recommend to solve this issue is to remove the vlan dot1q tag native command from the configuration and create a new separate and otherwise unused VLAN (let's call it the VLAN X) that will be configured as the native VLAN on all trunk ports except the one on which some particular VLAN needs to be untagged. As the VLAN X will be unused, no frames will be sent in it, thereby making the port using the VLAN X as the native VLAN to tag all other (i.e. effectively all) taffic.
Best regards,
Peter
Lei Tian
Hi Julxu,
Native VLAN tagging on a per port basis is supported after 12.2(33)SXH.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/dot1qtnl.html#Configuring_the_Switch_to_Tag_Native_VLAN_Traffic_Globally
Please rate if helps.
HTH,
Lei Tian
Hello Lei,
Thanks for letting us know about this. Wonderful! I did not know about that. This is definitely a better solution I've originally proposed above.
Best regads,
Peter
Hi Peter,
Thanks for the great rating. Glad that I can provide useful information.
Lei Tian
