Community Member
native vlan and security..
hello there...i need your help.. i heard that we should change native vlan number.. why? and what the consequences to change that native vlan1. ex:cdp,vtp,etc... tx anyway :)
Community Member
Re: native vlan and security..
the native vlan is vlan 1 by default.
But if you are configuring the trunk interface, you could change this problem by the command.
switch(config-if)#switchport trunk native vlan [vlan-id]
the untagged data traffic will be forwarding to the new native vlan.
Hall of Fame Super Blue
Attached is a link to a vlan security doc from cisco which explains the use of the native vlan and why it should be changed from vlan 1 which is the default.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a008013159f.shtml#wp39211
We use a non-routable vlan as our native vlan on all our switches. This vlan also never has any switch ports in it.
Vlan 1 will still be used to send cdp, vtp pagp between switches.
Jon
317
