08-29-2013 04:47 PM - edited 03-07-2019 03:12 PM
I need to connect a Cisco 2900 switch with a fiber port to a second Cisco 2900 that does not have any fiber ports. In order to not spend any money on transceivers/GBIC or any other converter type device I am using a third 3700 switch that has both types of ports as a big and expensive transceiver. Here is what I did:
Both Cisco 2900 switches are pretty much default config with no VLANs configured. The 3700 does have several VLANs and trunks configured and I would like to keep traffic on the 2900's segregated from the 3700's VLANs.
On the 3700 switch I took a fiber port and a copper port and made them access ports like this:
int gig3/0/44
switchport mode access
switchport access vlan 4455
int gig3/0/50
The config basically works and the two 2900's seem to be talking to each other well. But when I do "show CDP neighbor detail" and "show logging" on the 3700 I see the native VLAN mismatch errors on those two ports. I thought that by making these two ports access the fact that they are configured for VLAN4455 would be transparent to the 2900's. Should I worry about this error? I would like to get rid of it. What are my options here?
Diego
Solved! Go to Solution.
08-30-2013 02:30 AM
Hi Diego,
CDPv2 exchanges Native-VLAN information with a TLV:
http://www.rhyshaden.com/cdp.htm
I'm not aware of a way to disable this particular TLV but you could
- configure a logging discriminator to suppress this type of syslog message
- disable CDP on a per-interface basis
- enable CDPv1 on a per-interface globally (by disabling v2)
Feel free to ask further!
Rolf
08-29-2013 06:48 PM
Have you wiggled the cable?
08-29-2013 06:53 PM
It won't hurt anything it's just a informational message saying the vlan on the other end doesn't match . The only way would be to match the vlan on the 2900 which probably doesn't even allow you to configure a vlan that high or turn off cdp between the switches . That's a normal message but does not hurt anything.
08-30-2013 02:30 AM
Hi Diego,
Rolf
08-31-2013 08:49 AM
I think I will just have to train myself to live with it.
Thanks to all.
Rgds,
Diego
08-31-2013 10:38 AM
Hi Diego,
if you want to get rid of this type of syslog messages, you can configure a logging discriminator (if your IOS supports it):
logging discriminator NVM mnemonics drops NATIVE_VLAN_MISMATCH
logging buffered discriminator NVM
logging console discriminator NVM
#show logging
Console logging: level debugging, 37 messages logged, xml disabled,
filtering disabled, discriminator(NVM),
0 messages rate-limited, 71 messages dropped-by-MD
Buffer logging: level debugging, 37 messages logged, xml disabled,
Hope that helps
Rolf
08-31-2013 12:11 PM
Rolf,
If I can't train myself to ignore the error your suggestion is certainly a good one!
Thanks again,
Diego
