Native VLAN Mismatch
I have configured the port channel for two ports in Cisco 3750 switch. While connecting the cable in that port i am getting the native VLAN mismatching error. Below i have attached the configuration and error details. Please help me on this.
Error:
%CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet1/0/33 (5), with Core1 GigabitEthernet1/0/17 (1).
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/34, changed state to up
%CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet1/0/33 (5), with Core1 GigabitEthernet1/0/34 (1).
Configuration:
interface Port-channel3
description *****Connected to Dell Blade Server Switch****
switchport mode trunk
interface GigabitEthernet1/0/17
description *****Connected to Blade*****
speed 1000
duplex full
channel-protocol lacp
channel-group 3 mode active
interface GigabitEthernet1/0/33
description *****Spare*****
switchport access vlan 5
interface GigabitEthernet1/0/34
speed 1000
duplex full
Karthik
en
conf t
int g1/0/33
sw mo acc
sw acc vlan 1
end
wr
Alessio
PS: eagle eye !! thanks Peter
Hi Alessio,
sw acc nat vlan 1
You probably meant switchport access vlan 1 (i.e. remove the "nat" shorthand).
Your suggestion would surely remove the native VLAN mismatch issue. However, I also suggest verifying whether the Gi1/0/17 on Core1 is configured as an access port or if it is a trunk. If it is a trunk then clearly, the 3750 should also be configured as a trunk.
Best regards,
Peter
