06-22-2018 09:29 PM - edited 03-08-2019 03:27 PM
we getting some message in our core switch
%CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on TenGigabitEthernet1/0/8 (80), with DSW1.P1.A GigabitEthernet1/0/28 (1)
when we receive this log on our switch, at the same time we lost our connection with our server. and after re-login connection start normally.
TenGigabitEthernet1/0/28 (80) is our distribution switch where we create some port in vlan 80.
TenGigabitEthernet1/0/8 (80) is our router port( huwai). connected to our different location.
06-22-2018 10:36 PM - edited 06-22-2018 10:36 PM
Hi!
You are using diffrence native vlans, TenGigabitEthernet1/0/8 (80) you are using vlan 80 some natove and GigabitEthernet1/0/28 (1) you are using vlan 1. Can you post show Interface trunk and show run on both switchs?
/Mohammed
06-23-2018 04:26 PM
The native vlan must be the same on both ends (80 or 1), usually it does not affect but generates a lot of message, the best practice is not use the VLAN 1 for native vlan, create a new one just for that role and applied it under the trunk interfaces.
Hope it is useful
