Native Vlan Tagging
I have blow switch configuration :
Created by: D-Default, S-Static, G-GVRP, R-Radius Assigned VLAN
Vlan   Name   Ports  Created by
1      1 gi1-4,gi7-10,gi14-28,Po1-8 D
12     12 gi11-13 S
103    103 gi5-6 S
122     122 gi25 S
Can I add/pass new vlan 7 on gi11-13, these interface native vlan is1.
My doubt I if make the  gi11-13 inorder to pass the vlan 7 (by using command switchport trunk allowed vlan)  does it pass vlan 1 traffi as well?
How can we restrict traffic on gi11-13 for vlan 7 & 12.
Yes, I recommend create a new native vlan but consider in a future change the network under the VLAN 1 to other VLAN.
If you are going  to keep the VLAN 1 for users (not recommended, as Jon mentioned previously it is used for CDP, VTP, etc) you should allow the VLAN 1 over the Trunk and configure a new Native VLAN under the trunk, for example:
conf t
vlan 999
name NATIVE-VLAN
interface gi11-13
switchport trunk encapsulation dot1q (if it is not already explicitily)
switchport trunk native vlan 999
switchport trunk allow vlan 1,7,22
switchport mode trunk
no shutdown
*Remember if you are going to add a new VLAN over the trunk you need to use: add, otherwise it will be overwritten.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
8 Replies 8
The native VLAN is not required to pass over a trunk interface, You can filter the vlan 7 only and it will not generate any impact.
switchport trunk allow vlan 7,12
But is recommended to have the same native vlan on both ends.
When I will add the bleow command on gi11-13, doesnt it pass the vlan 1 traffic ? and That can cause issue.
 switchport trunk allowed vlan add 122
Nop it will not generate any issue, the native vlan can be omitted over a trunk.
The trunk will pass vlan 1 control plane traffic such as CDP, VTP etc. even if you do not allow it on the trunk but it will not pass any data traffic in that vlan.
So as Julio says no need to allow it on the trunk.
Jon
VLAN 1 is data Vlan configured in this switch
WebIntSw1#show running-config interface vlan 1
'interface vlan 1
ip address 172.30.0.23 255.255.255.0
no ip address dhcp
For security reason the vlan 1 should not be used and it should be shutdown, now you can create a specific native vlan but this vlan should not be used for other role in few words it should be used for any network or end user.
I suggest create a new vlan and assign the native vlan role.
If you want to should down the vlan 1 (recommended), you can execute the following commands:
configure terminal
interface vlan 1
shutdown
Thanks for help
In my case VLAN 1 already used, so I should create native VLAN for any new trunk prort.
So it should not pass VLAN 1 traffic
intreface gi11-13
#switchport trunk native vlan 3 (any non used vlan)
# switchport trunk allowed vlan add 7,12...
conf t
vlan 999
name NATIVE-VLAN
interface gi11-13
no shutdown
