Community Member
Natting Issue On my router
router 2911
attached a file of sh run.. any of you can please help me
i need to ping  only from subnet 10.10.47.0/24 to 77.240.55.0/24 not working.really messed up with this router.
kindest regards
srikanth
no attachment found .
Community Member
Sorry for the inconvenience
above i have attached file.
Thanks sreek
Purple
Hi sreek,
could you just stick with one post for the same problem, it will be easier for all of us to help you more efficiently.
Don't forget that members are also  working outside of helping people here on the forum so it won't make them answer more quickly posting multiple times.
Regards.
Alain.
interface GigabitEthernet0/1
ip address 182.72.152.42 255.255.255.248
ip access-group 101 in
ip nat outside
ip nat enable
ip virtual-reassembly
duplex auto
speed auto interface GigabitEthernet0/1
ip nat outside
ip nat enable
duplex auto
speed auto
This is your interface for internet and overload is done on GigabitEthernet0/2.1 which even does not exist in show run.
ip nat inside source route-map WAN-OUT interface GigabitEthernet0/2.1 overload
Change it to -
ip nat inside source route-map WAN-OUT interface GigabitEthernet0/1 overload
Then it should work.
Also for NAT two statements are required -
ip nat inside and ip nat outside
ip nat outside i do see in your configuration but rest interfaces are not configured for ip nat inside . You should also configure that.
Ajay
221
