Natting on Sub-Interfaces.
Hi, I would like to enable natting on my 4 sub-interfaces f0/1.1,f0/1.2,f0/1.3,f0/1.4, the ranges I would like to configure on each sub-interface is 192.168.1.0,2.0,3.0 & 4.0.
The exit interface for the traffic is f0/0 which is directly connected to my ISP. Can someone please guide me on this? I have attached the configuration plus I am posting it below:
#sh run
Building configuration...
Current configuration : 2211 bytes
! Last configuration change at 14:55:37 UTC Sat Oct 28 2006
! NVRAM config last updated at 14:57:14 UTC Sat Oct 28 2006
version 12.4
service password-encryption
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxx
aaa new-model
aaa session-id common
resource policy
ip subnet-zero
ip cef
ip domain name yourdomain.com
username admin privilege 15 secret xxx
interface FastEthernet0/0
ip address 194.54.x.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 2201
ip address 194.54.x.5 255.255.255.252
no snmp trap link-status
interface FastEthernet0/1.2
encapsulation dot1Q 2202
ip address 194.54.x.9 255.255.255.252
interface FastEthernet0/1.3
encapsulation dot1Q 2203
ip address 194.54.x.13 255.255.255.252
interface FastEthernet0/1.4
encapsulation dot1Q 2204
ip address 194.54.x.17 255.255.255.252
interface FastEthernet0/1.5
description **NMS**
encapsulation dot1Q 2205
ip address 194.54.x.21 255.255.255.252
ip classless
ip route 0.0.0.0 0.0.0.0 194.54.x.1
1 REPLY
Re: Natting on Sub-Interfaces.
The config could look like this:
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
ip nat inside
description **NMS**
ip classless
ip nat pool Sub1 192.168.1.1 192.168.1.254 prefix-length 24
ip nat pool Sub2 192.168.2.1 192.168.2.254 prefix-length 24
ip nat pool Sub3 192.168.3.1 192.168.3.254 prefix-length 24
ip nat pool Sub4 192.168.4.1 192.168.4.254 prefix-length 24
ip nat inside source route-map Nat4vlan2201 pool Sub1
ip nat inside source route-map Nat4vlan2202 pool Sub2
ip nat inside source route-map Nat4vlan2203 pool Sub3
ip nat inside source route-map Nat4vlan2204 pool Sub4
route-map Nat4vlan2201 permit 10
match ip address 101
route-map Nat4vlan2202 permit 10
match ip address 102
route-map Nat4vlan2203 permit 10
match ip address 103
route-map Nat4vlan2204 permit 10
match ip address 104
access-list 101 permit ip 10.1.0.0 0.0.255.255 any
access-list 102 permit ip 10.2.0.0 0.0.255.255 any
access-list 103 permit ip 10.3.0.0 0.0.255.255 any
access-list 104 permit ip 10.4.0.0 0.0.255.255 any
This assumes the IP addresses are 10.x/16 behind f0/1.x
You will need to adjust this and other numbers like ACLs to your environment.
Hope this helps! Please rate all posts.
Regards, Martin
107
