Community Member
NBAR question
Let's say I do this on my network:
class-map bittorrent
match protocol bittorrent
policy-map Outside
class bittorrent
drop
If someone changed their default bittorrent port, for example to port 80, would this circumvent detection?
If I then use "ip nbar port-map bittorrent tcp 80" to change the port monitored for bittorrent, doesn't this negate the purpose of NBAR - ie. to look further into the packet than just the port number in order to recognise traffic?
1 REPLY
Bronze
Re: NBAR question
The NBAR approach is useful in dealing with malicious software using known ports to fake being "priority traffic",
as well as non-standard applications using dynamic ports.
Below link which help you for the configuration of NBAR :
http://www.cisco.com/warp/public/63/nbar_acl_codered.shtml
113
