need a pbr expert
trying to convert a rather extensive policy from a router to a cat 3750. One problem is that cat does not support route-map delete but after looking at the doci if I understand it correctly that route-map delete is a way to fall out of the route-maps to fall into regular routing. If this is the case, can I do the same thing with a route-map permit but have no set commands?
thx again.
1 REPLY
Re: need a pbr expert
Yes, you can create a default route-map rule that catches all packets that
do not match specific rules. Then it will go via the regular routing
process. When you are using 3750, please make sure that you are running at
least IPServices image with your SDM template set to routing.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/1
2.2_35_se/configuration/guide/swiprout.html#wp1228588
Hope this helps.
NT
146
