Need clarification regarding the test cable-diagnostics tdr command
I've read about the test cable-diagnostics tdr command but I need clarification on the examples listed below to make sure that I am providing the right answer to my co-workers.
Example 1:
CXXX7SW17#show cable-diagnostic tdr int g0/20
TDR test last run on: July 16 10:23:00
Interface Speed Local pair Pair length        Remote pair  Pair status
Gi0/20    auto  Pair A     N/A                        N/A                Normal
                       Pair B     72   +/- 10 meters  N/A                Open
                       Pair C     75   +/- 10 meters  N/A                Short/Crosstalk
                       Pair D     74   +/- 10 meters  N/A                Short/Crosstalk
Does this example mean that there's a cable length issue in the line which is causing the device that it's connected to not to work properly?
Example 2:
CXXX2SW140#show cable-diagnostics tdr int g0/21
TDR test last run on: July 16 09:16:22
Gi0/21    100M  Pair A     N/A                      Pair A           Normal
                          Pair B     N/A                      Pair B           Normal
                          Pair C     N/A                     Pair C           Normal
                          Pair D     N/A                     Pair D           Normal
Does this example state that the cable line is okay for use?
Example 3:
CXXX1SW19#show cable-diagnostics tdr int g0/22
TDR test last run on: July 16 06:36:53
Gi0/22    auto    Pair A       1    +/- 10 meters  N/A               Open
                          Pair B     39   +/- 10 meters   N/A               Open
                          Pair C     72   +/- 10 meters   N/A               Open
                          Pair D     1    +/- 10 meters    N/A               Open
Does this example mean that there isn't a device connected on the other end? No pin-contact?
Thank you very much for any help you could provide.
S
1 REPLY
I found this article here at
I found this article here at supportforums that seemed like the best explanation I've read so far for TDR info.
Hope that helps.
3404
