Blue
Need Help ASAP. PoE Question
Got a 3750 running 12.1(19)EA1d
I get into the interface, execute the power inline auto command, but when I do a show power inline, it says its turned off...
Is there a global config command for PoE?
Does this 3750-24p switch running this code support PoE?
Re: Need Help ASAP. PoE Question
Does your switch support POE? There are some 3750's without POE.
Blue
This one should...when I do the show power inline command, it gives me an output instead of just saying that the switch doesnt support it.
137
