Need Help CAT4HK High CPU suspected high host learning process
I got an unusual high CPU utilization for my CAT4 during unusual hour of the day, The following times are
show ver is
#show version
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9K2S-M), Version 12.1(19)EW1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 28-Jul-03 15:59 by eaarmas
Image text-base: 0x00000000, data-base: 0x010254B4
ROM: 12.1(12r)EW
Dagobah Revision 86, Swamp Revision 28
XXXX uptime is 21 weeks, 13 hours, 0 minutes
System restarted at 05:25:12 SGP Mon May 22 2006
System image file is "bootflash:cat4000-i9k2s-mz.121-19.EW1.bin"
cisco WS-C4506 (XPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID XXXXX
Last reset from PowerUp
62 Gigabit Ethernet/IEEE 802.3 interface(s)
403K bytes of non-volatile configuration memory.
Below are the timings from my MRTG
Date Start Time End Time Duration
4-Oct-06 9:00 11:00 2:00
10-Oct-06 18:30 20:30 2:00
12-Oct-06 17:00 19:30 2:30
13-Oct-06 16:00 19:00 3:00
16-Oct-06 8:45 18:00 9:15
The show platform cpu packet statistics is attached.
I check on the PDF file see attached , but I can't find any relating to host learning, seems like something is doing some hacking in the network? any suggestions?
1 REPLY
Re: Need Help CAT4HK High CPU suspected high host learning proce
The STP looks stable and hence we can rule out that case.
However I could also see that "K2FibAdjMan Host Mov" process is also consuming cpu resources.
Check whether any host connected to the switching is flapping frequently.
Check whether you could get any useful information from "show logging" or if you have any syslog captured from the switching, examine those logs to see if you notice any huge host flapping events occurring during that time.
Check this link for more details on this
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml#adj
Hope this helps.
-VJ
925
