Need help clearing vlans
I have a C2924 and need to remove the vlans and leave the defualt ones only.
2 ACCEPTED SOLUTIONS
Silver
Re: Need help clearing vlans
Hi Javier ,
You mean you want only vlan 1 in your switch...
what is the meaning of "need to remove the vlans and leave the defualt ones only" ..
You can erase start up config and reload the switch if you want vlan 1 in your switch...
you can use the following coomand to delete a vlan from database....
no vlan
cheers :)
satish
u may try: "del vlan.dat"
Cheers!
Silver
Hi Javier ,
no vlan
cheers :)
satish
Cheers!
137
