Need Help Connecting (2) 2950 switches together, cant see each other
Can anyone please help me get my switches talking?  I am currently in training for entry level certs and can't continue until i get these talking.
I have two 2950 switches connected via port 0/1 on both switches.  (tried both crossover and regular cat5 connections)
I have both ports active and both VLAN 1s active and both ports set to switchport mode trunk
There is no port security enabled.  Both switches have IP's assigned in the respective default VLAN 1.
IP address 10.1.10.10 for switch 1
IP address 10.1.10.11 for switch 2
VTP is set to server on both, ( I tried transparent on both as well )
I cant get these switches to ping each other and or access telnet from each other.  If i connect an outside connection i can telnet individually to each but they wont see each other through ping or CDP Neighbors.
Any ideas?? Please help as i am trying to get my CCENT in a few weeks!
THANK YOU!
post here the configuration
 ******* SWITCH 1 LOGIN *****
 ******* SWITCH 1 LOGIN *******
User Access Verification
Password:
SW1>en
Password:
SW1#show run
SW1#show running-config
Building configuration...
Current configuration : 1884 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW1
enable secret 5 $1$TIuw$zBOptQNhwsRgZ6Frv.PVx.
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
 switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
 ip address 10.1.10.10 255.255.255.0
 no ip route-cache
ip http server
banner motd ^C ******* SWITCH 1 LOGIN ******* ^C
line con 0
 logging synchronous
 login
line vty 0 4
 password vty
 login
line vty 5 15
 password vty
 login
end
SWITCH 2 BELOW
 ****** SWITCH 2 LOGIN ******
banner motd
Password:
SW2>en
Password:
SW2#show run
SW2#show running-config
Current configuration : 1894 bytes
version 12.1
no service pad
hostname SW2
enable secret 5 $1$nSFY$umNCHgrkLGTwHyI.dkbJf.
ip subnet-zero
ip ssh time-out 120
interface Vlan1
 ip address 10.1.10.11 255.255.255.0
 no ip route-cache
ip http server
banner motd ^C ****** SWITCH 2 LOGIN ******
banner motd ^C
line con 0
 logging synchronous
 login
line vty 0 4
 password vty
 login
line vty 5 15
 password vty
 login
end
remove the vtp, or tests with
remove the vtp, or tests with one in client mode and the other one in server mode
Now you are still using a cross cable? if you use a cat5 cable on 2950 you must insert auto-mdix command
configuration seems ok
LEVANTE 86 Thank you for your
LEVANTE 86
Thank you for your reply, i found the issue.  BAD CABLE !!!
ok :D i supposed,it was a
ok :D i supposed,
it was a pleasure , if you want rating my comment, bye
195
