Need help for Fiber GLC-LH-SM connection between Cisco 3750
Please help me. I want to connect my two Cisco 3750 switch by gbic GLC-LH-SM.Unfortunately, when i trying to connect,it's not uplink.
More information about two switch below:
Gi1/0/51 notconnect 1 auto auto 1000BaseLX SFP
switch 2 show interface status
Gi2/0/51 notconnect 1 auto auto 1000BaseLX SFP
I have no idea to deal with it,any ideas ?
You need to make sure you are
You need to make sure you are using single-mode fiber between your two switches. It should be  yellow, 9 micron.  If you are using single-mode fiber, then make sure the A/B is not switched.
are the gbics cisco original
are the gbics cisco original ?
if yes then just make sure of the cable which should be Single mode.
if still not working try to reverse the cable connectors on one side as well.
88
