need help in loading IOS on 3750
nelba_aldovino
Hi all,
can anyone help me on what command i will execute on hyperterminal to copy the IOS from my pc to switch.
My problem is that the switch does not boot because the flash was not found.
I downloaded a flash but i dont know how to copy it from my pc to the switch using hyperterminal.
when i type this command:
switch: copy ?
this will show
usage: copy [-b <buffer_size>] <src_file> <dst_file>
what does buffer size mean and can someonegive me an example command on how to execute that command.
Please someone help me......
Leo Laohoo
You can try to "download" the IOS via the console cable using XModem, particularly the switch command  "xmodem -r -s 115200".  This command means that the IOS will be loaded into the DRAM (-r switch) and the upload will be using high speed at 115200 bps (-s switch).
Xmodem Console Download Procedure Using ROMmon
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Hope this helps.
Please don't forget to rate useful posts.  Thanks.
thank you for the reply.
as of now i'am trying this http://cisco.biz/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml.
i'll give updated if this become successful..
thank you again for the info.
