Need help on 6506 boot problem
viett
Hi all,
I have a 6506 with “ WS-X6K-SUP2-2GE”. The switch does not boot after restart, it goes to “rommon” mode, I have to manual enter command “Boot” then it boots and everything works like normal. The boot command is on configuration file (attached file)
Please, help.
Ivan Shirshin
Check 2 things:
1. The boot variable "disk0:s222-ipservicesk9_wan-mz.122-18.SXF11.bin" is pointing to correct location and file really is there.
2. Config-register should be 0x2102 both on router and switch processor. Execute "remote command switch show boot" for the SP output (RP is fine per the outputs you attached). To fix the config-register problem, you should configure it to default value and save configure to sync its value between SP and RP:
     conf t
          config-reg 0x2102
          end
     wr
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
6 Replies 6
Reza Sharifi
Can you delete the existing boot variable save the config and reapply the boot variable again, save and reboot?
boot system slot0:
Reza Sharifi
Please make sure to reboot during an outage window, as rebooting will cause disruption to your network.
Ivan Shirshin
Check 2 things:
     conf t
          config-reg 0x2102
          end
     wr
Kind Regards,
Ivan
Kind Regards,
Ivan
Fully agree with Ivan.
You can also execute "confreg" at the rommon to set it interactively ( if rommon supports it)
rommon> priv
rommon> confreg
rommon>sync
rommon>reset
Thanks and Regards,
Prajul.
viett
Thanks for all your help.
Glad to help
Kind Regards,
Ivan
