need help "converting" these catos commands to ios
We want to replace a dying Cisco WS-C2948G-GE-TX with a WS-C2950T-24. The 2948 has CatOS while the 2950 has Cisco IOS.
The 2948 was configured by someone who left the company a while while back. I'd like to duplicate the config of it on the 2950. Here are the settings of the 2948:
Console> (enable) sh config
begin
# ***** NON-DEFAULT CONFIGURATION *****
#time: Mon May 11 2015, 03:45:41
#version 8.3(2)GLX
#system web interface version(s)
set config mode text nvram
#dot1x
set feature dot1x-radius-keepalive disable
#frame distribution method
set port channel all distribution mac both
#Local User
set localuser user username password $1$3LOg$wmSL4EobKoom8hZ54Pbsf1 privilege 15
#vtp
set vtp domain domainname
#ip
set interface sc0 43 10.1.1.82/255.255.255.240 10.1.1.95
set interface sl0 down
set interface me1 192.168.2.201 255.255.255.0 192.168.2.255
set ip alias default 0.0.0.0
#rcp
set rcp username cgi-edm
#dns
set ip dns server 20.1.1.1 primary
set ip dns server 20.1.1.2
set ip dns domain domain.com
#syslog
set logging console disable
#http configuration
set ip http server enable
#multicast filter
set igmp filter disable
#module 1 : 0-port Switching Supervisor
#module 2 : 52-port 10/100/1000 Ethernet
set vlan 43 2/46-47
set port speed 2/47 10
set port duplex 2/47 full
clear trunk 2/47 1-1005,1025-4094
set trunk 2/47 off dot1q
clear trunk 2/48 2-40,44-1005,1025-4094
set trunk 2/48 on dot1q 1,41-43
end
Console> (enable)
I've changed some of the IP addresses to fictitious ones.
2/46, 2/47, 2/48 will be equivalent to fa0/22, fa0/23, fa0/24 respectively.
So far I've assigned fa0/22 and fa0/23 on the 2950 to vlan43 and I've set fa0/23 to 10/full. I'm not sure how to do the rest :(
  • LAN Switching and Routing
1 REPLY
Re: need help "converting" these catos commands to ios
274
