Webcast-Catalyst9k
Need help to build a catalyst 4500 switch BoM.
I want to purchase a catalyst 4500 switch. I have the following requirements.
1. 12 fiber ports (SFPs)
2. 48 10/100/1000 Ethernet ports
3. redundant power supply
4. 1 year smartnet support and other necessary equipments.
I chose following Equipments as BoM
1. WS-C4507R
2. PWR-C45-4200ACV/2
3. WS-X4516-10GE
4. WS-X4548-GB-RJ45
5. WS-X4306-GB
6. GLC-T
7. S45ESK9-12237SG
8. MEMC4K-512D-SDRAM=
9. MEM-C4K-FLD128M
10. CON-SNTE-4507R2S5
I would be thankful if anybody help me out whether this configuration fulfill my requirement or not.
1 ACCEPTED SOLUTION
Re: Need help to build a catalyst 4500 switch BoM.
Same as in buying an illegal/pirated DVD than a legal one. To make software legal, you will need to purchase license for it. Also, I would think the ordering tool would not let you complete order without including software.
Looks good to me but I am not sure what features will be deployed on this switch.
In my opinion, Sup5-10GE which is primarily designed for 10 slot chassis might be an overkill for your 7 slot unless you are looking for 10 Gig uplinks. You could save some green by considering a Sup4(WS-X4515) or even a Sup2+(WS-X4013+) if this switch is not at the core and not meant for very feature rich deployment. Also, 4507R supports redundant Supervisors and you might want to consider this as well.
Can I use an IOS downloaded from cisco.com for Cat 4500 instead of purchased one ?
What is the difference between downloaded and purchased IOS ?
569
