Webcast-Catalyst9k
Need help with cisco 1811 dual wan port forward config
I'm trying to configure cisco 1811 with dual isp internet connections. Everything is working fine till i get to setting up port forwards.
The port forwards for 2nd ISP do not work while connection to 1st isp is active. If if shutdown the connection to isp1 the port forwards work fine.
here's relevant section of the config
[CODE]
track 123 ip sla 1 reachability
delay down 15 up 10
track 456 ip sla 2 reachability
delay down 15 up 10
interface FastEthernet0
description COMCAST WAN
ip address 50.78.x.x 255.255.255.240
ip nat outside
ip virtual-reassembly in
shutdown
duplex auto
speed auto
no cdp enable
interface FastEthernet1
description ATT DSL
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface Vlan1
description LAN
ip address 192.168.20.51 255.255.0.0
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username ****t password 0 ****
ip nat inside source route-map WAN1 interface FastEthernet0 overload
ip nat inside source route-map WAN2 interface Dialer0 overload
ip nat inside source static tcp 192.168.2.131 80 50.78.x.x 80 route-map WAN1 extendable
ip nat inside source static tcp 192.168.2.131 80 69.0.x.x 80 route-map WAN2 extendable
ip nat inside source static tcp 192.168.1.210 3389 69.0.x.x 3389 route-map WAN2 extendable
ip route 0.0.0.0 0.0.0.0 50.78.x.x track 123
ip route 0.0.0.0 0.0.0.0 Dialer0 track 456
route-map WAN1 permit 10
match interface FastEthernet0
route-map WAN2 permit 10
match interface Dialer0
ip sla 1
icmp-echo 8.8.8.8 source-interface FastEthernet0
threshold 40
timeout 1000
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 4.2.2.2
threshold 40
timeout 1000
frequency 3
[/CODE]
I can access the 192.168.2.131 web server using the ISP1 ip but not ISP2 ip
If i shutdown ISP1 interface the server becomes accessible through ISP2.
Also while ISP1 is active I can't remote desktop to 192.168.1.210
There are no acls, firewall zones or anything else.
I would appreciate any help on this.
538
