Need help with installation new 1MFT Wic controller
I am tryig to install a T1 controller 1mft Wic in a 2811 router. I don't see the contoller to configure it. I do see it if I run sh diag but not in show config. What am I missing to register the card so can set it up for voice.
Re: Need help with installation new 1MFT Wic controller
If it is a T1/E1 card, you need to first configure "card type t1 0 0", depending on what slot you have the card in.
it is a daughter card in slot 0 but the router won't take card type as on option?
What is the part number of the card?
WIC Slot 0:
T1E1 (1 port) WAN daughter card
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : A0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC10520QNU
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
So that card will do either T1 or E1, in global config, you should be able to use the card type command.
TGO-MKE-Honeycreek-Router#
TGO-MKE-Honeycreek-Router#config t
Enter configuration commands, one per line. End with CNTL/Z.
TGO-MKE-Honeycreek-R(config)#card
TGO-MKE-Honeycreek-R(config)#card ?
% Unrecognized command
Hmm. What version of IOS?
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.3(8)T8, RELEASE SOFTWARE (fc1)
I thought maybe I was loosing my mind. Very odd nothing seems to be working
Well, I can't vouch for your mind ;), but it sure seems like it should be working. Maybe try a different slot, or a reload?
maybe a reload of the IOS? I do have 2 cards and installed the second into another slot to see if that would make a difference but no luck. Strange it shows in sh diag but can't configure it?
Or maybe go up to 12.4, if you don't mind running that.
I will try that tomorrow and see what happens
thanks for the help
168
