Need help with routing
I have two networks with an older IAD2431 I am using for testing.
Here is my setup:
Eth 0/0 - 192.168.134.10 255.255.255.0
Eth 0/1 - 172.16.1.254 255.255.0.0
From the 192.168 network (my pc was at 192.168.134.101) I can ping any IP address that is in the 172.16.1.X range but cannot ping anything other than the .1.X range.  It is acting like it is supposed to be a class C network.  For example if I try to ping 172.16.2.1 it fails.
I can ping any 172.16 address from the router but not from the 192.168 network.  If I do a tracert it stops at 192.168.134.10.
This has also happened to me on a HP router that I had a while back.  I'm sure it is something that I am doing but I don't know where to start.
Re: Need help with routing
Think you're going to need to post some configs.
It is pretty basic, I am only using the two ethernet ports right now.  Here is the config.
Router#show run
Building configuration...
Current configuration : 1188 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
!card type command needed for slot 1
no aaa new-model
network-clock-participate wic 0
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
archive
log config
  hidekeys
controller T1 0/0
framing esf
linecode b8zs
controller T1 0/1
framing esf
linecode b8zs
interface FastEthernet0/0
ip address 192.168.134.10 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.31.0.1 255.0.0.0
duplex auto
speed auto
no ip http server
no ip http secure-server
ip forward-protocol nd
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
line con 0
line aux 0
line vty 0 4
login
end
you have a class a address space on the 172 side. What is the gateway address on the hosts on that subnet?
You also need ip classless in your config.
229
