Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Need helpful suggestion !!
I have 125 systems including FTP and EMAIL servers positioned through 5 departments. Now I want to be them in a fully switched and routed environment with internet connection and lan connection in each of them. Also I want to enable telnets in switches and ssh in routers so that they can be accessed for configuration from remote location. I am planning to go with v-lan and inter-vlan routing. Kindly suggest me:-
1. How many routers and switches ideally required for this and their model numbers.
2. Which routing protocol can I use to make the routing?
3. How to introduce internet connection in this network.
4. I want to use smart card login facility to check the entry and exit of people.
5. Also suggest me whether I should go with VLAN or not.
PS: For the telnet and ssh part I need no help, I just need help regarding the architecture and addressing (whether can I go for VLSM or normal classfull addressing from different private networks.)
Thanks in advance !!
Everyone's tags (5)
322
