Webcast-Catalyst9k
need info : 3725 router as terminal server
friends,
i need to configure 3700 series router as terminal server. any link would be greatful
i see lot of posts with 2500 series being configured as terminal server.
thanks in advance.
Sara
1 REPLY
Re: need info : 3725 router as terminal server
Configuration of 3700 router as a terminal server is similar to the 2500
configuration. The only difference will be the line numbers (which depends
upon the module you are using and where you have inserted it).
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_exampl
e09186a008014f8e7.shtml
If you issue "show run" it will list the terminal line numbers in the
configuration. Then you can follow the above procedure for remaining
configurations.
Hope this helps.
NT
295
