Need Login to console when TACACS enable
I faced the problem in login to the router through console when TACACS password is enable.
I need to know what teh command to disable teh tacacs login,when we need to login to console.
Re: Need Login to console when TACACS enable
Please anyone help me quickly as i am in downtime window.
Hall of Fame Super Silver
I am not clear what it is that you need. When you login on the console do you want it to authenticate via TACACS? Since that is the default when TACACS is enabled I assume that this is probably not what you want.
So do you want to bypass TACACS when you login on the console? If so then give this a try:
line con 0
login authentication cons
and use this if you want to authenticate with the console password
aaa authentication login cons line
or use this if you want to authenticate with locally configured user ID
aaa authentication login cons local
or use this if you want no authentication for the console
aaa authentication login cons none
Or if this is not what you want then please clarify what it is that you want.
Rick
373
