07-27-2013 11:03 AM - edited 03-07-2019 02:38 PM
my router has taken a poop. it is in a constant loop when i start it up and loads the image, then i comapared it with another router to see where it malfunctions and this is where is does, it says;
00:00:10 UTC Fri Mar 1 2002: Unexpected exception to CPUvector 100, PC = 0x801BA270, LR = 0x801CD2F8
-Traceback= 0x801BA270 0x801CD2F8 0x801CC840 0x801CC01C 0x80105ED0 0x80101750 0x801CE010 0x801C91B8 0x801C9328 0x81708A1C 0x809F344C 0x809F372C 0x8064C76C 0x8064FE70
CPU Register Context:
MSR = 0x00009032 CR = 0x22000024 CTR = 0x801CD2AC XER = 0x20005765
R0 = 0x00001032 R1 = 0x829EEDB0 R2 = 0x82650000 R3 = 0x00000003
R4 = 0x00000000 R5 = 0x00000000 R6 = 0x82650000 R7 = 0x68010000
R8 = 0x00009032 R9 = 0x82280000 R10 = 0x68010000 R11 = 0xC0000000
R12 = 0x22000022 R13 = 0xFFF4A9E4 R14 = 0x809F36E8 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x829EEDE0 R27 = 0x00000000
R28 = 0x00000000 R29 = 0x68000000 R30 = 0x00000000 R31 = 0x00000000
Free space check for flash:crashinfo_20020301-000010 failed (1016/1302)
=== Flushing messages (00:00:10 UTC Fri Mar 1 2002) ===
Queued messages
*** System received a SegV exception ***
signal= 0xb, code= 0x100, context= 0x82846ed0
PC = 0x801ba270, Vector = 0x100, SP = 0x829eedb0
07-27-2013 01:22 PM
Can you break to ROMMON mode?
07-27-2013 06:16 PM
yes i can get into rommon mode.
07-27-2013 01:26 PM
Usually, Traceback message indicate memory leak and hardware issues, but it could also be IOS realated Try loading a different IOS and watch it for a period on time.
What type of router and what IOS are you running?
07-27-2013 06:15 PM
hello,
it is a 2600
System Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
TAC Support:
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 65536 Kbytes of main memory
old legacy
07-27-2013 07:13 PM
Yes, 2600 series is very old. I would try a different IOS.
07-27-2013 07:37 PM
Your router is undergoing what is known as a crash-boot-loop. Basically it's crashing and it boots, natural behaviour. While it is booting up, it writes a crashinfo file. Seeing that your router has no more flash memory space, it crashes again. And it'll keep doing this until you free up some more flash space.
07-27-2013 07:56 PM
Once you get to ROMMON mode, try issuing "dir flash" and see if there is anything you can delete. if you aren't sure what you can delete, paste the output back to this thread.
There are some helpful ROMMON commands here
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/rommon.html#wp1020562
07-28-2013 07:49 AM
rommon 5 > dir flash:
File size Checksum File name
15813348 bytes (0xf14ae4) 0xe6d6 c2600-entbase-mz.124-25d.bin
287415 bytes (0x462b7) 0x9e97 crashinfo_20020301-001133
134846 bytes (0x20ebe) 0x3961 crashinfo_20020301-081927
4785 bytes (0x12b1) 0xd7c3 crashinfo_20020301-081951
1320 bytes (0x528) 0xf04e crashinfo_20020301-000010 (deleted)
5652 bytes (0x1614) 0x674c crashinfo_20020301-001314
1320 bytes (0x528) 0xdffb crashinfo_20020301-000010 (deleted)
1320 bytes (0x528) 0xe903 crashinfo_20020301-000010
it is nothing but crash info, im actually trying to learn with my home lab and study for my ccna. so while this is a good learning experience it is also a pain because i can move forward. im trying to pass the ccna before sep 30 before they change the test.
do you think it could be a hardware problem with the memory
also i have another router and i saved the flash file on a tftp, but i cant seem to copy tftp flas, inside the rommon mode
07-28-2013 09:35 AM
Try this to copy from tftp to flash:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Try deleting most of those crash files and see if the router will boot to the software image. I don't think that will help, but it's worth a shot. I think you have a hardware issue with the memory module or corrupt flash.
07-28-2013 09:56 AM
rommon 13 > delete flash: crashinfo_20020301-001133
monitor: command "delete" not found
is there another way to delete in rommon
it is probably a bad mem mod, cause it was working fine then ka-blewy, no connection to the other router and when i went over to see what was going on it was in a rebootloop cycle.
might just by another
07-28-2013 03:34 PM
Your syntax is incorrect. There's a
Try this: delete flash:crashinfo_20020301-001133
Heck, I think you can get away with: delete flash:crashinfo*
07-29-2013 02:11 PM
hey leo thanks for the reply,
i tied many ways but it says that the "delete" command is not found.
thank anyways
08-05-2013 12:11 PM
leo,
you were helping me with this issue and i tried somthing and it back fired on me, please help.
i figured it was the memmory module that went bad so i took one from another router i had and switched it and it still did not boot, it went to rommon mode.
here is the kicker, i put the memmory back into the router that was working fine and now it is doing the same thing, they are both the same router and specs. it says it exceeds mem, but does not. also this router was working perfectly before i swapped to diagnose the mem. mod.
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0xf14944
Error : memory requirements exceed available memory
Memory required : 0x02711C48
*** System received a Software forced crash ***
signal= 0x17, code= 0x4, context= 0x800805d0
PC = 0x0, Vector = 0x0, SP = 0x0
rommon 1 > dir flash:
887 bytes (0x377) 0x125d stary
any thoughts??????????????
08-05-2013 12:48 PM
sorry everyone and thanks i found the problem. the first router having the problem was the module must have popped out the first time(no clue how). then when i swapped i actually did the same thing and did not push hard enough to pop it in all the way.
i realized this when it loaded and i saw it said only 32 mb of main mem and i knew i had 64mb
so i figured out that the module was not in all the way, i popped it in it then said 64 mb and went to set-up mode
thanks,
i wont bother you anymore
