Need some help with a WS-C2960G-48TC-L
Hi guys, my first time on here.
Im having an issue with a WS-C2960G-48TC-L
It boots up ad this is what happens
flashfs[0]: 530 files, 21 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 18167296
flashfs[0]: Bytes available: 14346752
flashfs[0]: flashfs fsck took 11 seconds.
...done Initializing Flash.
done.
Loading "c2960-lanbasek9-mz.122-44.SE6.bin"...c2960-lanbasek9-mz.122-44.SE6.bin:
no such device
Error loading "c2960-lanbasek9-mz.122-44.SE6.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960-lanbasek9-mz.122-44.SE6.bi
File "flash:/c2960-lanbasek9-mz.122-44.SE6.bin" uncompressed and installed, entr
y point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagr
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(44)SE6, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 18:10 by gereddy
Image text-base: 0x00003000, data-base: 0x01100000
Initializing flashfs...
flashfs[1]: 530 files, 21 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 18167296
flashfs[1]: Bytes available: 14346752
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
1 Retry (ASICs Detected 0,configured 12)
MIC Conf reg value 111 0
MIC PCS INfo 0x0
MIC Interrupts received 0x0
2 Retry (ASICs Detected 0,configured 12)
MIC PCS INfo 0x0
3 Retry (ASICs Detected 0,configured 12)
MIC PCS INfo 0x0
4 Retry (ASICs Detected 0,configured 12)
MIC PCS INfo 0x0
5 Retry (ASICs Detected 0,configured 12)
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
MIC PCS INfo 0x0
Any help would be greatly appreciated!
VIP Super Bronze
Re: Need some help with a WS-C2960G-48TC-L
Hi Reza.
Welcome to the forum.
It seems that you have a bad/corrupted image installed.  Can you download a new copy of the IOS and reload it again?
Reza
I have done that. when i dir flash: this is what i get
switch: dir flash:
Directory of flash:/
    2  -rwx  7075072                  c2960-lanbasek9-mz.122-44.SE6.bin
    3  drwx  192                      crashinfo_ext
    5  drwx  128                      crashinfo
    6  drwx  192                      c2960-lanbasek9-mz.122-44.SE6
14346752 bytes available (18167296 bytes used)
switch:
Hall of Fame Super Gold
Hold on ... Did you download again from the Cisco website?  Or did you re-upload the suspected corrupted file?
I got the file from cisco and xmodem it. the crash info was not there until after i put the new file on and rebooted the unit
I go with Reza (+5).  I've never used the SE6 flavour.  Use 12.2(55)SE instead.
VIP Super Bronze
I would delete the current one on flash and download:
c2960-lanbasek9-mz.122-55.SE.bin
Once this image is loaded into flash reboot the switch.
Make sure you don't reboot the switch when there is no image on the flash
Reza
how should i delete the current file? once i boot the unit i wont let me do anything. i cant get to switch> mode. can i do that from switch: mode?
format flash:
what is the BOOT file suppose to look like? when im in switch: set?
Hey Reza,
Based on the error messages that you are seeing:
MIC PCS INfo 0x0
I would say that you have a faulty switch.  I would open a TAC case to have this switch replaced via RMA.
Adam
1607
