Need some help with N7K vPC
Hi, I had some trouble while deploying vPC and here is my network topology:
I have two nexus 7009 as core switch, both of them are vPC enable and vPC adjacency formed ok.
The switch-B (2960-S)  dual-home to two n7k, the uplink ports are config as normal port-channel on 2960 and vPC on N7K. While I connecting a PC on either N7k-1 or N7K-2 and accessing to server A or server B , everthing works fine.
After that I have a access switch (switch-A) dual-home to two n7k, and the uplink ports are config same as the switch-B, the host-A can accsee both server behind switch-B.
but for some reason, the link toward to the n7k-2 was removed. Since that the host behind the switch-A accessing the server which  behind the switch-B seems unusual. some of them can access all server but some of them cannot!
While I show ip arp on both n7k, I found that arp table are not sync. for some client , I can ping it either on n7k-1 or n7k-2. When I try to ping those client on server, and debuging ip packet on two n7k, the switch-B choose n7k-2 as next hop ( base on hash algorithm), I can get debuging message on n7k-2 but not on n7k-1, it seems that n7k-2 not passing that packet to n7k-1 or n7k-1 drop that packet? So I try the same action on other server, this time the switch-B choose the n7k-1 as the next hop and I get debuging message on n7k-1, the server can also get ICMP relay.
The same thing happen while client acquiring IP using core-switch as dhcp-relay, some client can't receive the DHCP offer, but I actually capture the DHCP discover & offer packet on the DHCP server! I was totally confused……
Can somebody tell me why that happen? and how to fix it?
Here is the port-channel config:
interface port-channel 2
  description To_Server_Switch
  switchport
  switchport mode trunk
  vpc 2
interface port-channel1
  description To_Access-switch
  switchport
  storm-control broadcast level 40.00
  vpc 1
Here is show vpc output
vPC domain id                     : 10
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 31
Peer Gateway                      : Enabled
Peer gateway excluded VLANs       : -
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
show vpc output
vPC status
id   Port   Status Consistency Reason                     Active vlans
1    Po1    up     success     success                    1,5-37,41-5
2    Po2    up     success     success                    1,5-37,41-5
Everyone's tags (4)
330
