Need SSO help - Sup7203b's
Well I have been back and forth on this awhile now...I have a 6513E chassis that is getting prepped for prod.
I am currently testing sso functionality and I can only get it to work using the following images
on both Sup Cards
s72033-adventerprise_wan-mz.122-33.SXI5.bin
If I try any other image, smaller or bigger in size...it forces my Sup card in mod 8 to recycle " proxy request from peer "
I have tried K9 images and non K9 images.
Here is an output from sh redundancy
Redundant System Information :
       Available system uptime = 4 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 7
        Current Software state = ACTIVE
       Uptime in current state = 3 minutes
                 Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISE_WAN-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 01:29 by prod_rel_team
                          BOOT = disk0:s72033-adventerprise_wan-mz.122-33.SXI5.bin,1;
                   CONFIG_FILE =
                       BOOTLDR = bootflash:
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 8
        Current Software state = STANDBY HOT
       Uptime in current state = 0 minutes
                          BOOT = disk0:s72033-adventerprise_wan-mz.12.2-(33)SXI5.bin,12;
                   CONFIG_FILE =
Heres a sh mod
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL13410GF9
  3   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAD074003KU
  7    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL13431ZWK
  8    2  Supervisor Engine 720 (Hot)            WS-SUP720-3B       SAL09306D4F
10    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1448197E
11   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1431PFV8
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0027.0d35.a270 to 0027.0d35.a287   4.1   12.2(18r)S1  12.2(33)SXI5 Ok
  3  000d.29f6.9880 to 000d.29f6.98af   5.0   7.2(1)       12.2(33)SXI5 Ok
  7  001f.6c77.7670 to 001f.6c77.7673   5.9   8.5(3)       12.2(33)SXI5 Ok
  8  0013.c42e.7168 to 0013.c42e.716b   4.4   8.5(2)       12.2(33)SXI5 Ok
10  1cdf.0f84.3d10 to 1cdf.0f84.3d13   3.2   12.2(14r)S5  12.2(33)SXI5 Ok
11  d0d0.fd64.aeb8 to d0d0.fd64.aee7   3.4   12.2(18r)S1  12.2(33)SXI5 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL134324T6  4.1    Ok
  7  Policy Feature Card 3       WS-F6K-PFC3B       SAL13421NL5  2.6    Ok
  7  MSFC3 Daughterboard         WS-SUP720          SAL13421LZ8  4.0    Ok
  8  Policy Feature Card 3       WS-F6K-PFC3B       SAL092963W3  2.1    Ok
  8  MSFC3 Daughterboard         WS-SUP720          SAL09295MWF  2.3    Ok
10  Centralized Forwarding Card WS-F6700-CFC       SAL144816SB  4.1    Ok
11  Centralized Forwarding Card WS-F6700-CFC       SAL1431PB6L  4.1    Ok
Cheers
Dave
VIP Super Bronze
Dave,
Your SSO redundancy looks fine. The primary is active and the stand-by is HOT. Does it do the same thing, if you switch Sups? (Put the one that reboots in module 7 and the current promary in module 8)
Yeah with this image, SSO works fine...I havent tried swapping the slots...I'll give that a try.
I noticed that the versions of MSFC3's and PFC3's are different, would that make a difference ?
288
