Need to connect Avaya Phones to Cisco 3750x
Hi.  i need to connect avaya phones to the Cisco 3750x switch. if i connect the phone on an independent port it works. but if i want to connect the ophone and dassy chained the phone with a PC , the Avaya Phone will get the ip address of the Data VLAN.
Why? --- >See the config below.
note:
- IOS version c3750e-universalk9-mz.122-55.SE5.bin
-Data VLAN 100
- Voice VLAN 200
... truncated config ...
switch 1 provision ws-c3750x-48p
switch 2 provision ws-c3750x-48p
switch 3 provision ws-c3750x-48p
switch 4 provision ws-c3750x-48p
switch 5 provision ws-c3750x-48p
switch 6 provision ws-c3750x-48p
switch 7 provision ws-c3750x-48p
switch 8 provision ws-c3750x-24p
system mtu routing 1500
ip routing
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.27.230 192.168.27.254
ip dhcp excluded-address 192.168.28.1 192.168.28.20
ip dhcp excluded-address 192.168.28.230 192.168.28.254
ip dhcp excluded-address 192.168.27.1 192.168.27.35
ip dhcp ping packets 3
ip dhcp pool VOICE-VLAN200
   network 192.168.28.0 255.255.255.0
   default-router 192.168.28.1
   domain-name hq.uha.local
   option 242 ascii "MCIPADD=192.168.28.7,MCPORT=1719,HTTPSRVR=192.168.28.8"
   dns-server 172.16.6.124
   lease 3
vlan 100
name UHA-DATA_VLAN100
vlan 200
name UHA-VOICE-VLAN200
interface GigabitEthernet2/0/38
switchport access vlan 100
switchport trunk native vlan 100
switchport trunk allowed vlan 100,200
switchport mode trunk
switchport voice vlan 200
no cdp enable
spanning-tree portfast
! note ---> if i connect a phone on port 2/0/38 it DOES NOT WORK. Phone register on vlan 100. WHY ?
!                  what configuration changes I need to performed for the Avaya phone be sense on the correct Voice VLAN
!                  and it can work with a PC on the DATA VLAN simultaneously on port 2/0/38.  kindly advice.
!                  Note that the Data VLAN DHCP is on another router  10.172.198.126 and is working fine.
!                  Kindly advice ASAP.
interface GigabitEthernet2/0/39
switchport access vlan 200
switchport mode access
speed 100
duplex full
spanning-tree bpduguard enable
!   note  ---> if i connect a phone on port 2/039 it works. but it can only support one vlan.
...truncated config ...
interface Vlan100
description UHA-DATA_VLAN100
ip address 192.168.27.254 255.255.254.0
ip helper-address 10.172.198.126
interface Vlan200
description UHA-VOICE_VLAN200
ip address 192.168.28.1 255.255.255.0
Bronze
Hello Victor,
AVAYA phones do not use CDP to discover the voice VLAN (or if a voice VLAN is being used at all) and we have to tell them to tag the packets by using DHCP options (this is configured on the DHCP server).
We need to create a custom option.
The option 176 will have to reside in the data VLAN DHCP server as well as the voice VLAN DHCP server.
L2Q=1,L2QVLAN=XXX (XX being the voice vlan)
Note: Use option 176 for 46xx models or option 242 for 96xx models.
Haihua
hello Haihua
I am unclear of what i need to do. I tried this statement in diferent location and it did not worked
Can you please paste an example ASAP
thank you for your generosity
Victor,
You can trunk the ports that the phones connect to if you're connecting pc to phone and phone to data jack. The phone is told how to tag packets as Haihua stated above. You put the option 242 in your dhcp scope. Workstations will ignore the option, but the phone will pick it up. If you're connecting it the way I stated above, you need to put the scope in the data vlan and the voice vlan. The data vlan is configured exactly as stated above, but the voice vlan scope needs to have other options like:
MCIPADDR=x.x.x.x,MCPORT=1719,HTTPSRVR=,L2Q=1,L2QVLAN=
When the phone gets an address from the data vlan, it will get the string to tell it to move to the voice vlan. After it moves, it will pull another address and this new 242 string to tell it where to find the call server, voice vlan, http server for updates to the bin file, etc.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Bronze
Hello Victor,
Under the interface for data:
option 242 ascii "MCIPADD=192.168.28.7,MCPORT=1719,HTTPSRVR=192.168.28.8,L2Q=1,L2QVLAN=40"
Haihua
908
