Webcast-Catalyst9k
Need to Enable SSH instead of Telnet on Cisco Catalyst 2950 / 2960 Series S
Dear All,
Pls guide me how to enable SSH on Cisco Catalyst 2950 / 2960 Series SW?
I Need to Enable SSH instead of Telnet on Cisco Catalyst 2950 / 2960 Series SW.
Or is it not possible ?
1 ACCEPTED SOLUTION
Re: Need to Enable SSH instead of Telnet on Cisco Catalyst 2950
Hello!
First of all you need an IOS version that support crypto (c2950-i6k2l2q4-mz.121-22.EA12.bin for C2950 as an example), then you have to enable SSH on the switch with "crypto key generate rsa" and then on the "line vty 0 4" you have to do "transport input ssh" or "transport inpus ssh telnet" if you want ssh and telnet (I recommend this until you are sure that ssh is working without problems).
Good luck!
Cheers,
Calin
Hello!
Good luck!
Cheers,
Calin
Thank you sir...
Dont forget to enable "AAA new-model" in Global Config for a text book configuration :-)
6774
