Community Member
Need to get some understanding on L2 l L3 Vlan
Hi Friends,
I have a doubt, if it seems very simple question plz forgive: )
I have a LAN setup with few cisco 3750 switches, where i am using VTP mode as Transparent.
What will happend If i create a L3 Vlan SVI interface with out creating L2 on the switch.
What is the difference in creating L3 Vlan with L2 and with out L2 ?
Please can any one take some effort to brief me about this..
Thanks a lot
Jacob
1 REPLY
Re: Need to get some understanding on L2 l L3 Vlan
Jacob,
When you create an SVI interface because is a virtual interface without any physical associations, at least you must have one L2 VLAN created for it with a connected device or host on a switchport to associate it with that newly created SVI interface in order for the SVI interface to be fully up and functional. A virtual SVI interface without any L2 vlan association in a switchport will just be an idle SVI interface, this would be the case when no L2 VLAN is associated with L3 interface the expected output of " show ip interface brief " for the SVI will be Up/Down.
Same as above answer, once you create L2 VLAN in vlan database and connect a device or host on a switchport that will bellong to L3 SVI network that you have created, the SVI interface will be a fully functional as well as fully routable and be able to route between any other L3 interfaces or SVI you have similarly created.
-Jorge
117
