Need to replace IOS in Running MSFCs in 6506 Core switch - Pls Help !!!
Dear Sir,
I need to replace IOS in Cisco Catalyst 6505 core switch.
Ols scenario :
POY_MSFC2#dir bootflash:
Directory of bootflash:/
1 -rw- 14827396 Jan 28 2009 20:39:27 +05:30 c6msfc2-jsv-mz.121-26.E3.bin
31981568 bytes total (17153916 bytes free)
POY_MSFC2#sh bootvar
BOOT variable = bootflash:c6msfc2-jsv-mz.121-26.E3.bin,1
CONFIG_FILE variable =
BOOTLDR variable =
Configuration register is 0x102
Now I need to replace this IOS with
c6msfc2-jsv-mz.121-8b.E6.bin
I have copied it in bootflash:.
Now scenario is :
2 -rw- 12269252 May 26 2009 13:53:13 +05:30 c6msfc2-jsv-mz.121-8b.E6.bin
31981568 bytes total (4884664 bytes free)
POY_MSFC2(config)#boot system flash bootflash:c6msfc2-jsv-mz.121-8b.E6.bin
BOOT variable = bootflash:c6msfc2-jsv-mz.121-8b.E6.bin,1
BOOTLDR variable =
Now presently older IOS is running. So I need to reload to use newer IOS.
I had reloaded MSFCs but new IOS was not used.Instead Older one is loaded and Bootvar is changed automatically like this :
BOOT variable = bootflash:c6msfc2-jsv-mz.121-26.E3.bin,12;bootflash:c6msfc2-jsv-mz.121-8b.E6.bin,1
BOOTLDR variable =
Now how to resolv it pls suggest ?
Should I del older IOS from Bootdisk: ?
Weather it will allow to del it as the same IOS is running?
Pls Reply Soon.
1 ACCEPTED SOLUTION
Re: Need to replace IOS in Running MSFCs in 6506 Core switch - P
no boot system flash bootflash:(imagename).
for both the images and save u r config.
And add the new statement and save u r config.
Mahmood
Can u remove both the boot statements and add the new statement with the new image and save ur config.
Mahmood
Hi Mahmood
Thanks for the reply.
Could you pls tell me how can I remove it?
Weather it will affect the running system as other Card on the same CORe switch is running and NW is working on that Card.
Pls reply soon
Deepesh
Mahmood
405
