11-19-2007 06:46 PM - edited 03-05-2019 07:31 PM
hi,
1) First question, What the best Backbone & layer 2 switch (must support Trunking) i'll buy on this scenario
Backbone Switch(support ACL)locate at Server room
Layer 2 Switch (support Vlan)use for every floor Switch.
For Example for backbone, we configure 6 Vlan with different IP address.
For each Floor we configure Different Vlan Example
first Floor on ly have 2 Vlan ( Vlan 1 and Vlan 3).
2nd Floor only 3 Vlan ( Vlan 1 3 and 6).
and same other....which configure different Vlan.
2 ) Second question, is there a way that we can configure Trunk Vlan to make backbone and layer 2 switch communicate because each Floor only have one cat6 cable to connect to backbone switch..?
3) Can we assign Ip address of each Vlan to become a gateway for each pc assign on the Vlan..?
Thanks in advance
11-19-2007 08:50 PM
HI, [Pls Rate if HELPS]
Backbone Switch:
CISCO Cat 4000 Series Switches
L2 Switches:
CISCO 2950 Switches
Eg: Trunk Scenario
Floor I port 1/24 (trunk) ==> Server Room
Foor III port 1/24 (trunk) ==> Server Room
Trunk Port:
>> Will carry all VLAN Traffic to the Server Room Backbone Switch
Eg: VLAN as Gateway Scenario
VLAN2: 10.1.0.0 (Subnet)
Gw: 10.1.0.1
VLAN3: 10.2.0.0 (Subnet)
Gw: 10.2.0.1
The 1st IP Address of each VLAN Subnet can be used as VLAN Router IP and same as GW for CLients.
Hope this Helps
Pls Rate if HELPS
Best Regards,
Guru Prasad R
11-19-2007 09:47 PM
Hi..
thanks for a quick reply, btw can we used CISCO cat 3560 as a Backbone switch..
11-19-2007 10:28 PM
Go-ahead and pls see it supports all your Backbone Requirements as planned.
Organization Size / Density: Medium-Sized means it is recommended.
Refer link below for CISCO Cat 3560 Data Sheet:
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_data_sheet09186a00801f3d7d.html
Pls Rate if HELPS
Best Regards,
Guru Prasad R
