Needing advice
I would like to install a gigabit switch for max 12 users, wireless capable, security options, include 'guest' access via wired ports, can handle wired/wireless cameras.
What model should I be looking at? the Cisco site isn't too easy to figure this out.
thanks so much,
Wondering
Re: Needing advice
I would consider either a 3560 or a 2975.
Hall of Fame Super Gold
Re: Needing advice
You can get a 3750G-24WS (Catalyst 3750 Series Integrated Wireless LAN Controllers)
It is a:
1. 24-port PoE (Standard PoE only) 10/100/1Gb ethernet port; and
2. Built in Wireless LAN Controller (can control a minimum of 25 AP's to a maximum of 50 AP's).
Does this help?
Cisco Catalyst 3750G Integrated Wireless LAN Controller Data Sheet
www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps7185/ps6915/product_data_sheet0900aecd804b0879.html
116
