Netflow 3750x config
Rawa Salah
Hello Dears
Your assistance so appreciated !
I have configured Netflow on my switch c3750x ios (15.0(2)) , as the following configuration :
flow record Netflow
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 collect interface input snmp
 collect interface output snmp
 collect counter bytes
 collect counter packets
flow exporter Netflow-to-Solar
 destination 192.168.1.1
 source tengigethernet 1/1/1
 transport udp 2055
flow monitor Netflow-Capture
 record Netflow
 cache timeout inactive 10
 cache timeout active 5
interface TenGigabitEthernet1/1/1
ip flow monitor Netflow-Capture input
ip flow monitor Netflow-Capture output
but from my solarwind netflow analyzer , said that ( Data is not available ) . just please help to solve what the issue ?
6 Replies 6
1- Check if UDP 2055 port is allowed on your firewall
2-your analyzer must be configured to accept incoming flow, check its configuration.
3- check your netflow version on your switch and server
Can you do the following command and provide the output please:
show flow exporter Netflow-to-Solar
Manny
Marvin Rhoads
Can you also confirm that you have the C3KX-SM-10G services module?
Dear
Actually no , because i am using c3kx-nm-10g , this service module not support netflow ?
Check out this link and it should clear up the difference between the C3kx-nm-10g and C3kx-sm-10g
https://supportforums.cisco.com/ru/discussion/11568246
Correct - the plain 10 Gbps network module does not add Netflow support on the Catalyst 3650X. You need the service module ("c3kx-sm-10g") as it has the necessary ASIC built-in.
