Netflow in Cisco 6513 with Sup 2T
After installing Cisco 6513 with 2T sup engine, we have configured netflow as below. But we did not received any data in Netflow server (CA NetQoS).
flow record NFRec
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match ipv6 traffic-class
match ipv6 protocol
match transport source-port
match transport destination-port
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter NFExp
destination x.x.x.x
source Loopback0
option exporter-stats timeout 20
flow monitor NFMon
record NFRec
exporter NFExp
interface Vlan x
description xxxx
ip address x.x.x.x x.x.x.x
ip flow monitor NFMon input
ip flow monitor NFMon output
We have alos raised a query with OEM CA for netflow, and as per them
These are the minimum required fields by RA using v5 flows for data to appear in ReporterAnalyzer:
1 - IN_BYTES
4 - PROTOCOL
7 - L4_SRC_PORT
8 - IPV4_SRC_ADDR
10 - INPUT_SNMP
11 - L4_DST_PORT
12 - IPV4_DST_ADDR
14 - OUTPUT_SNMP
You can take this issue further with vendor
In Wireshark, we checked and found that INPUT_SNMP and OUTPUT_SNMP parameters are not coming.
It is resolved now. We just need to add below two parameters in Flow Record.
collect interface input snmp
collect interface output snmp
Thanks...
165
