10-12-2010 02:59 AM - edited 03-06-2019 01:27 PM
Hi everybody,
I need help regarding Netflow
I have this message in log file:
%EARL_NETFLOW-SP-4-TCAM_THRLD: Netflow TCAM threshold exceeded, TCAM Utilization [97%]
I know that indicates the TCAM is almost full.
I use sup 720 with PFC3BX
I wanted to disable completely the Netflow by
no mls flow ip
Result: I still got the same log message above, however I find no mls flow ip in the running configuration file.
Any help to fix the issue would be appreciated.
regards
Alioune
Solved! Go to Solution.
10-12-2010 03:35 AM
10-12-2010 03:35 AM
Hi Alioune,
You could try "no mls netflow".
Jack
10-12-2010 06:36 AM
Thank you Jack, indeed the no mls netflow command fine.
I no more get the log messages.
I have one question what command disable the Netflow?
I tried no mls netflow ip , but it was not disable it.
thank you.
Alioune
