Netflow on 4510
I have i customer with a ws-c4510R-E , the supervisor is a 6-E.
They want netflow enabled on the switch.
It is possible?
5 ACCEPTED SOLUTIONS
Re: Netflow on 4510
  Sorry guy, It doesn't support netflow on your supervisor(6-E).
Ref: http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/configuration/nfswitch.html
HTH,
Toshi
Netflow on 4510
Yes, Netflow is supported with Sup v-10 GE with an integrated daughter card.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps6033/product_data_sheet0900aecd801c5c66_ps4324_Products_Data_Sheet.html
Netflow is also supported on new SUP7-E
Cheers,
-amit singh
Netflow on 4510
Yes it is supported.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet0900aecd801792b1.html
However, you can have only classic cards in slot 8-10.
Hope this helps.
-amit singh
Netflow on 4510
Hi Rafel,
SUP 7-E of course
This gives you 848 Gbps switching capability with new 4510R+E chassis with 48 Gbps per slot. Even with the older 4510R-E chassi, it gives 24Gbps per slot. SUP 5 only support 6 Gbps per slot as its being a classic sup engine.
SUP 7- E supports many advanced features like Flexible Netflow ( you can define your custom fields for netflow), Hardware ready for VSS, MACSEC ready, Wireshark logging on-board, UPOE etc...
Please have a look at the datasheet.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/data_sheet_c78-612364.html
Cheers,
-amit singh
Netflow on 4510
You need minimum IP Base image IOS -XE 3.1 on the SUP7-E.
Make sure that you have the IP base loaded on the system.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_23474.html#wp2518375
HTH,
-amit singh
Re: Netflow on 4510
HTH,
Toshi
Netflow on 4510
What about the Supervisor Engine V-10GE.
Netflow on 4510
Cheers,
-amit singh
Netflow on 4510
is the sup7-e supported on 4510-E ?
Netflow on 4510
Hope this helps.
-amit singh
Re: Netflow on 4510
which supervisor is better? the sup7-e vs Sup v-10 GE ?
is netflow supported on the sup7-e with the 4510R-E chassi?
Netflow on 4510
Hi Rafel,
SUP 7-E of course
Cheers,
-amit singh
Re: Netflow on 4510
what I need to have netflow with sup7-E on this chassi (4510R-E)?
Netflow on 4510
HTH,
-amit singh
2863
