Netflow on a 6503
fiene3606
I have a customer who has an existing 6503 in place, and they are interested in turning on Netflow. I do not believe they are licensed to run it. Here is a show versions if that helps any:
echnical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Sat 08-Jul-06 03:13 by kellythw
Image text-base: 0x40101040, data-base: 0x42D88000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF5
, RELEASE SOFTWARE (fc3)
OWHB_6503_1 uptime is 7 weeks, 6 hours, 54 minutes
Time since OWHB_6503_1 switched to active is 7 weeks, 6 hours, 54 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 02:49:29 extended_DST Wed Apr 11 2007
System image file is "sup-bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6503-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of m
emory.
Processor board ID FOX10021594
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
29 Virtual Ethernet/IEEE 802.3 interfaces
74 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Does anyone have any idea the minimum IOS or licensing I need to have them purchase in order to get them the ability to turn on Netflow?
Thank you.
T
5 Replies 5
royalblues
Level 10
Level 10
Amit Singh
T,
You have Sup 720 and it supports Netflow on it. However,You would need to have a Cisco Netflow collector application that is running either on a Linux/Solaris server.
Informations data is avaialble and collected by
netflow but for doing the bandwidth analysis and/or reporting you will need Cisco Netflow collector application or 3rd Party netflow analayzer.
Cisco has Network Analaysis Module for Cat6500 for netflow accouting.The NAM has independent backplane interfaces for SPAN/VACL traffic and for NetFlow. The NAM uses the collected packets to provide information on applications, hosts, conversations, etc.
Enabling Netflow:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/netflsol/nfwhite.htm#xtocid2867938
Page for NAM:
http://www.cisco.com/en/US/products/sw/cscowork/ps5401/index.html
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet0900aecd804bab11.html
HTH,Please rate if it does.
-amit singh
Amit,
So based on what you see, there are no additional licenses or higher IOS level that they need to buy or upgrade to? I know the software looks like it supports it, but based on what you see, as long as they have a collector, which they do, they can just turn Netflow on on this device?
Tyler
They should be able to just turn on Netflow. There are no additional licensing requirements to run Netflow on the 6500.
Rick
Rick
I have only this command:
6509(config)#ip flow export ?
layer2-switched layer2 switched flow
I can?t use ip flow-export destination x.x.x.x 9995
why?
We use sup720
