netflow question for IPv6 traffic
    I tried to setup to my 3640 to export ipv6 traffic.  I used continuious "ping ipv6"  from one window xp system to remote window xp sytem via my network.  From the ping ipv6 are ok, I can get the ping echo back all the time. but, from the netflow-export collector (tool) and wirshark I didn't see any records for IPV6. I did see some records for IPv4 from wireshark andnetflow-export collector (tool).
Not sure does this caused by my configuration problem, or the image or the harware not support? anyone can help will be appreciate.
  I checked Cisco Feature Navigator, my SW version c3640-js-mz.124-23.bin which shall support NetFlow and  Netflow for IPv6 Unicast traffic.
     the following is my show ver, show run information and show ip cache flow information.
Li Miaw
lmiaw@netsocket.com
O1#show ver
Cisco IOS Software, 3600 Software (C3640-JS-M), Version 12.4(23), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 08-Nov-08 23:43 by prod_rel_team
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
O1 uptime is 1 hour, 2 minutes
System returned to ROM by reload
System image file is "flash:c3640-js-mz.124-23.bin"
Cisco 3640 (R4700) processor (revision 0x00) with 123904K/7168K bytes of memory.
Processor board ID 26857169
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
2 Ethernet interfaces
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
====   show run  ====
O1#
O1#
O1#
O1#show run
Building configuration...
Current configuration : 2342 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname O1
boot-start-marker
boot system flash c3640-js-mz.124-23.bin
boot-end-marker
enable password cisco
no aaa new-model
ip cef
no ip domain lookup
ipv6 unicast-routing
ipv6 cef
mpls traffic-eng tunnels
username admin password 0 adminn
interface Loopback0
ip address 10.22.1.1 255.255.255.255
interface Tunnel0
no ip address
ipv6 address FE80::202:B3FF:FEA6:F151 link-local
tunnel source 3.0.0.1
tunnel destination 1.0.0.1
tunnel mode ipv6ip
interface FastEthernet1/0
ip address 10.12.4.22 255.255.255.252
ip route-cache flow
duplex auto
speed auto
ipv6 address 192:168:1:1:10:12:4:16/126
ipv6 enable
ipv6 flow ingress
ipv6 flow egress
ipv6 ospf 10 area 0.0.0.0
mpls ip
ip rsvp bandwidth 1024 1024
interface FastEthernet1/1
ip address 10.12.4.14 255.255.255.252
ip route-cache flow
duplex auto
speed auto
ipv6 address 192:168:1:1:10:12:4:E/126
ipv6 enable
ipv6 flow ingress
ipv6 flow egress
interface Ethernet2/0
description connect to CE2 f1/0
ip address 3.0.0.1 255.0.0.0
ip route-cache flow
half-duplex
ipv6 address 192:168:1:1:3::1/120
ipv6 enable
ipv6 flow ingress
ipv6 flow egress
interface Ethernet2/1
no ip address
ip route-cache flow
shutdown
half-duplex
ipv6 enable
router ospf 1
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
no ip http server
ip forward-protocol nd
ip flow-export source FastEthernet1/0
ip flow-export version 9
ip flow-export destination 1.0.0.10 9995
snmp-server community public RO
snmp-server ifindex persist
snmp-server enable traps snmp linkdown linkup
snmp-server enable traps tty
snmp-server host 10.12.2.2 version 2c public  snmp
ipv6 router ospf 10
router-id 10.22.1.1
ipv6 flow-export source FastEthernet1/0
ipv6 flow-export destination 1.0.0.10 9995
control-plane
dial-peer cor custom
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
line vty 0 4
privilege level 15
password cisco
logging synchronous
no login
end
O1#
===show ip cache flow ====
O1#
O1#show ip cache flow
IP packet size distribution (50022 total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .000 .871 .124 .003 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 278544 bytes
  8 active, 4088 inactive, 1457 added
  21851 ager polls, 0 flow alloc failures
  Active flows timeout in 30 minutes
  Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 21640 bytes
  8 active, 1016 inactive, 1455 added, 1455 added to flow
  0 alloc failures, 0 force free
  1 chunk, 1 chunk added
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
TCP-Telnet         210      0.0       207    41      9.0       3.4       3.0
TCP-other          117      0.0         1    52      0.0       3.0      15.5
UDP-other         1119      0.2         5    71      1.2       0.0      15.4
ICMP                 1      0.0         2    56      0.0       0.2      15.3
IPv6INIP             2      0.0         5    93      0.0       2.1      15.8
Total:            1449      0.3        34    45     10.3       0.8      13.6
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP  Pkts
Fa1/1         10.12.2.2       Local         10.22.1.1       06 C778 0017    46
Fa1/1         10.12.2.2       Local         10.22.1.1       11 810A 00A1     2
Fa1/0         10.22.3.1       Local         10.22.1.1       06 4A9E 0286     2
Fa1/1         10.12.2.2       Local         10.22.1.1       11 5588 00A1    13
Fa1/1         10.12.2.2       Local         10.22.1.1       11 66F7 00A1     1
Fa1/1         10.12.2.2       Local         10.22.1.1       11 271E 00A1     1
Fa1/1         10.12.2.2       Local         10.22.1.1       11 7B7F 00A1     3
Fa1/1         10.12.2.2       Local         10.22.1.1       11 7D98 00A1    17
Everyone's tags (2)
1 REPLY
Bronze
Can you try with flexible NetFlow export? My blog has some info on how to create a NetFlow record which includes IPv6 conversations:
https://blogs.manageengine.com/netflowanalyzer/2011/04/13/ipv6-and-netflow-netflow-analyzer-ipv6-data-reporting
For flexible NetFlow configuration guide, check the below link:
http://www.cisco.com/en/US/docs/ios/fnetflow/configuration/guide/fnetflow_overview_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if you have got your answer.
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
738
