Community Member
Netflow SW 3850 configuration to work with Netflow (Layer 7)
Hello Everybody.
I need all the help as possible.
Recently I configured a SW-3850 (IOS XE) to send records about NETFLOW to OP MANAGER Software Collector. Everything works without problem but. The System administrator ask me send "Layer 7 Application" because he wants a relation about the traffic.
The collector has a header like this:
And the software has a demo where the same section has the next information complete:
The configuration SW is the next:
flow record NFRECORD_IN
match ipv4 version
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match flow direction
collect counter bytes long
collect counter bytes layer2 long
flow record NFRECORD_OUT
match ipv4 version
match ipv4 tos
match ipv4 protocol
match interface output
flow exporter NFEXPORTER
destination "some"
source Vlan1
transport udp 9996
option exporter-stats
option application-table
flow monitor NFMONITOR_IN
exporter NFEXPORTER
cache timeout active 60
record NFRECORD_IN
flow monitor NFMONITOR_OUT
exporter NFEXPORTER
record NFRECORD_OUT
But I can't that the SW does or send the information or view information int the "Layer 7 Application" section
I tried with AVC, but in this case doesn't because AVC with the command "match application name" is for WLAN.
Someone can Help me?
80
