Netfow is not working for WS-4500 CAT, Port 9996 is locked
****************************************Related Running Configuration**************************************
flow record EID
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 collect interface output
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
flow exporter EID
 destination 10.250.2.50
 source GigabitEthernet2/14
 transport udp 9996
 template data timeout 60
 option interface-table timeout 60
 option exporter-stats
flow monitor EID
 record EID
 exporter EID
 cache timeout active 60
ip subnet-zero
Test#sh run int gi2/14
Building configuration...
Current configuration : 122 bytes
interface GigabitEthernet2/14
 switchport access vlan 202
 switchport mode access
 ip flow monitor EID input
end
vlan configuration 220
vlan internal allocation policy ascending
***************************************************************************SHOW VER****************************************************************
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.02.00.SG RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 26-Apr-11 18:09 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Image text-base: 0x100A0994, data-base: 0x13CAB728
ROM: 15.0(1r)SG2
Jawa Revision 7, Snowtrooper Revision 0x0.0x116
EID uptime is 45 weeks, 5 days, 4 hours, 24 minutes
Uptime for this control processor is 45 weeks, 5 days, 4 hours, 26 minutes
System returned to ROM by reload
System restarted at 15:08:19 KSA Thu Aug 14 2014
Running default software
Last reload reason: Unknown reason
License Information for 'WS-X45-SUP7-E'
    License Level: ipbase   Type: Permanent
    Next reboot license Level: ipbase
cisco WS-C4510R+E (MPC8572) processor (revision 8) with 2097152K/20480K bytes of memory.
Processor board ID FOX1539G9WE
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from Reload
13 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
*****************************************Troubleshooting Done********************************
Flow Exporter EID:
  Packet send statistics (last cleared 1d03h ago):
    Successfully sent:         115713                (103853856 bytes)
  Client send statistics:
    Client: Option options exporter-statistics
      Records added:           165
        - sent:                165
      Bytes added:             5280
        - sent:                5280
    Client: Option options interface-table
      Records added:           155800
        - sent:                155800
      Bytes added:             16203200
        - sent:                16203200
    Client: Flow Monitor EID
      Records added:           2136496
        - sent:                2136487
      Bytes added:             81186848
        - sent:                81186506
EID#telnet 10.202.1.1 996 /source-interface vlan 220
Trying 10.202.1.1, 996 ...
% Connection refused by remote host
Everyone's tags (1)
29
