network Delay
hi gentleman's
Matthew can be said that the slow network affect the performance of programs in the servers
we have campus with 3 building 3 tier network diagram.
the application department says the delay in network affect on the application. but the ping between switch and distribution or access is <1ms
from core to distribution 1G also from distribution to access is 1G
Is there a way to know Is there a slow network or not
1 REPLY
Gold
network Delay
Client to server with a capture (Wireshark).
Even money bet there are some tcp window settings that can be modifed.
You need to:
a. establish a baseline from an endstation NIC to the server (ping and trace route)
b. then capture a conversation at the app layer over the same path.
277
