10-05-2007 12:31 PM - edited 03-05-2019 06:55 PM
Say I want to set up 2 networks.
I dont want to route between them and I want them to be on the same switch.
So I want each computer to be part of 2 network.
What is the best way to set that up? I've never done it so I want to be sure of how it would be done.
10-05-2007 07:02 PM
Use a layer 2 switch, two VLANS.
Each PC / host gets two NICs, each NIC is on its own subnet.
Each of the two NICs plugs into the associated VLAN.
No magic there at all.
Good Luck
Scott
10-05-2007 09:07 PM
If PC NIC's support trunking, could also have each PC on both VLANs logically using just one NIC.
10-08-2007 09:42 AM
If you use windows XP PCs, then use a layer 3 switch make diffrent VLAN and assign 2 set of IP address ( of 2 VLANS) with in XP PC
To add extra IP address goto advanced property of the NIC and set
