Community Member
network diameter
Hi !
I would like to know how I should calculated a diameter of a network for spanning-tree ?
thanks a lot !
2 ACCEPTED SOLUTIONS
Re: network diameter
Go over this link which provides ilustrated diagram and calculations performed by default stp timers through the layer 2 footprint.
From what I understand the recommended diamater by ieee on 802.1d is 7 hops.
http://www.cisco.com/warp/public/473/122.html
Rgds
Jorge
Hi Christian,
For simplicity, the STP network diameter is the highest possible number of switches a frame can go through when travelling across the layer2 network, by touching each switch only once (because the network being loop-free).
For example:
3 switches connected in triangle: the highest number of switches from edge to edge is 3.
Diameter is 3.
Cheers:
Istvan
Rgds
Jorge
Community Member
thanks a lot !
Hi Christian,
For example:
Diameter is 3.
Cheers:
Istvan
663
